-   -   Fuel Line Plumbing and Water Seperating Filters (https://www.offshoreonly.com/forums/general-q/79150-fuel-line-plumbing-water-seperating-filters.html)
Poorsche 05-16-2004 03:59 AM
I've got the engines out of boat and am re-rigging the engine compartment. There are water/fuel seperating filters on bulkhead for ewach engine and there is a similar filter on each engine as part of EFI system.
Are the exter filters causing a reduction in fuel flow? Is the filter on engine adequite for fuel/water problem?
Would love to get rid of the filters on bulkhead since they are from the previous engine installation. Would appreciate any comments--
Poorsche
www.boatmat.com
TxTaz 05-16-2004 08:24 AM
Re: Fuel Line Plumbing and Water Seperating Filters
What type of engine? Mercruiser does not recommend adding extra filters to the fuel system. It messes with the ECM.
Poorsche 05-16-2004 11:59 AM
The engines are MarinePower EFI 454 with Arizona Speed induction and ECU.
I was guessing the filters on bulkhead filters (which reamined from Mercruiser 370 TRS carb engines) needed to go and rely only on engine mounted water/fuel seprating filter.
Would appreciate confirmation.
