-   -   Battery Switch Swap (https://www.offshoreonly.com/forums/general-q/79519-battery-switch-swap.html)
waterheater 05-20-2004 11:10 AM
Battery Switch Swap
Any advice on swapping battery switches? Have a Guest and am switching to a lockable Cole Hersee. Not sure of degree of difficulty. Any suggestions?
Mr Gadgets 05-20-2004 07:28 PM
Re: Battery Switch Swap
WaterHeater..
It is a simple process, just disconnect your batteries and remove the Guest from it's mounting place. You should see two inputs from the battery and one output going to the starter..
The new switch should be the same..
Just remember to disconnect the battery cables from the battery before you start.
Good luck
Dick
waterheater 05-25-2004 07:08 AM
Thanks Dick, appreciate the advice. Sounds simple enough.
