honing plates
do you always use honing plates while honing? or is it just for hi performance applications?
Re: honing plates
Always use honing plates... The reason for the plates is the bolts tend to distort the top of the cylinder area... if the cylinders are finished without torque plates to distort the cylinder top during finishing ... then when you torque the heads on... there are distinct "high spots" around the top rim of the cylinder... Right where the top piston ring needs to seal.. so there is a loss of compression .. right where you need it most... Having your cylinders finished with torque plates installed isn't that much more money... but worth it.
Re: honing plates
Depends on the person that I am buildingthe motor for . They usally will let me get it done if they want a better ring seal. It not that much more $
Rob |
Re: honing plates
ok my problem is; they do not use it here in turkey, but i use them.
now i am building a very serious engine with lots of turbo boost. today i left the parts to engine machining shop and turned back home,when i opened the rear of my car i saw the plate there, i called the shop and told them they forgot to take the plate but he said he already done overboring and honed... piston to wall measure ,i told him is very close to max, which means i ahve very very small tolerance there. now i am thinking : when i arrive there tomorrow morning and install the plate ; can i save the block or machining without that plate makes so much difference ? do i have to forget about the current block this is a very special block,its told that liner can not be installed ..... aluminum 5cyl engine any comment? |
Re: honing plates
Honing torque plates are most beneficial when the cylinders are a cast part of the block.. such as BBC's and SBC's .On engines that have "wet liners" , where the block is alloy and the liners are steel... then they aren't as beneficial. What kind of engine are you working on?
Re: honing plates
audi 5 cylinder 20 valve engine
factory specs : 315 hp 20psi boost aluminum block and heads,dohc my expectation : 600+ hp >30 psi boost |
Re: honing plates
hp and boost levels look like 'not true' right?
Re: honing plates
Re: honing plates
1 Attachment(s)
LOL;
i stopped smoking weed long time ago but you know my dyno has some serious problems with coc. :):) |
Re: honing plates
1 Attachment(s)
thnx for plate help;
* this results do not belong to my car, i am still building mine, these are results from same engine,same configuration |
| All times are GMT -5. The time now is 01:36 PM. |
