Can't fill fuel tank...puking vent?!?
I has that problem on my Liberator no check valve on the vent line and it was 10' long with a low point in the middle, had to blow the gas out of it, also had a fuel pressure issue because of this(the reason I found it) lost all types of high end boat woulkd surge then slow down on it's own
If I missed this in a post, sorry... but that happened to me and the sending unit in the tank was bad. Expected to put 90 gal into a 120 gal tank (the first time) and it only took 35.
Then started spitting.
In the end it was full. The gauge reading was bad.
Always read just over a quarter tank.
I have a new theory...on the trailer, boat sits level and fueling is no problem. Sitting in the water, the weight of the motor, transmission and TRS assembly causes the boat to "squat". The fuel filler and vent connections are at the extreme aft end of the tank.
Is it possible, due to this extreme angle, that the tank won't fill as all the gas is settling toward the back of the tank?
D. Ocean
Pompano Beach, FLA
D. Ocean
Pompano Beach, FLA
Originally Posted by 818181
The vent probably is clogged, Try low pressure [10-15lbs.] air thru vent.
D. Ocean
Pompano Beach, FLA
If the vent hose lays lower than the tank at any point or even lays on top of the tank lower than the vent fitting on the top of the tank the hose can trap fuel in it. If fuel is trapped in the hose it will not let air past it. Make sure the hose is higher than the tank the full travel so any fuel can run downhill back into the tank. This seems to be a big problem on the new boats with the vent in the fuel fill.
