Merc Impellor Part number help
The number I have crosses into the plastic housing assembly anyone have the number for just the inpellor?
Re: Merc Impellor Part number help
Just the vaned rubber impellor: (no housing/kit)
Alpha: 89840 Bravo: 89740 Internet searches work pretty good for this kind of thing. |
And my boats break a lot, so I do this all the time. :D
you are correct internet searches are good for this sort of thing and also for semi correct information that is the part number for an aftermarket impeller.
I have tried the globe after market one and lost water pressure and had premature failure so I wanted to go back to the standard Merc for which the correct part number is 47-89984T4 but thanks for the help anyway |
I thought that people who looked for part numbers on a bulletin board always used aftermarket.... sorry. :D
I got to jump in here in regards to the Blue Globe Impellor. I also lost water pressure but that in turn reduced the maximum water pressure I was seeing at WOT. I ended up at 8 psig at idle and no more than 25 psig at 5000 rpm.
I was also using a crossover with bypass that had a 3/8" orifice in it. 142 degree T-Stat with (3) 3/16" holes. 155 degree operating temperature. Needed to control the oil temp though. I now will be using a Mercury Racing Oil Filter Mount with T-Stat. Sorry to go off on a tangent but losing water pressure was not a bad thing for my setup but a welcomed result of using the Blue Globe Impellor. Russ |
I will take the time to inspect after one season of use.
Thanks for the info Klaw. |
I use www.mercurypartsexpress.com to find part numbers and also to buy parts. A Merc dealer told me if I got the part number and called him I could save the up to 40% markup that Merc does.
| All times are GMT -5. The time now is 12:43 PM. |
