-   -   Power Steering Pump Question (https://www.offshoreonly.com/forums/general-q/79935-power-steering-pump-question.html)
Pat McPherson 05-26-2004 07:36 AM
I think my power steering pump is on the way out. :(
It is screaming a bit, but does not seem to be getting hot.
I have pulled the belt off and there is a lot of movement (shucking in and out), if i pull on the pulley.
I think it's best I just change it before I end up with oil everywhere.
Anyway, my question is the pump on my 1999 7.4MPI any different from an automotive pump?
Can I just go to an auto parts store and buy a power steering pump for a 7.4 truck engine?
I don't want to be completely cheap, but if I don't have to buy from a marine dealer, it would be easier...
Danny_Ocean 05-26-2004 08:06 AM
Re: Power Steering Pump Question
Can't say for sure, but when I rebuilt the power steering pump on my Corvette (1974), the thing looked exactly like the pump in my boat.
D. Ocean
Pompano Beach, FLA
OPIE272 05-26-2004 08:33 AM
Buy a rebuild kit for the pump and do it yourself if you can. Might not be able to but it is worth a try.
Cignificant 05-26-2004 08:36 AM
Pat, I just replaced the one on my 1990 Cafe. Do a search on power steering pumps and it will give you the NAPA part number for the one I used..
OPIE272 06-01-2004 08:49 AM
2480150389 ...........2480665336..................2480818233. .....2480824826
on E-Bay
SSComp 06-01-2004 02:01 PM
Standard GM
Falcon 06-01-2004 06:40 PM
I believe the main pump section of just about all of the gm pumps is the same. There are slight differences in output because of combinations of "relief valve/spring/output orifice diameter/connection type" of the removable main thread in valve body. Other differences are of course in the type of reservoir.
Pat McPherson 06-01-2004 06:45 PM
Thanks Guys!
I bought the Napa one listed...
Have not had a chance to check if it will work yet.
p4-33 06-01-2004 11:32 PM
Just curious what one costs at Napa. I just bought a new Merc Blue one for $320.
Thanks,
Brian
Pat McPherson 06-02-2004 06:49 PM
The Napa pump is a reman for $68 with a $16 core charge.
Have not made the switch yet, hoping it will not be that different.
