Need Help Carb Gaskets
I am replacing the base gasket on my Holley. And I can't seem to get the same answer on this one...Do I use a base gasket with 4 holes or with one big one(the open square type)? And given the answer to that why? What happens if you use the
"wrong" one? Randy "Bad-Habit" |
Re: Need Help Carb Gaskets
match the gasket to the intake manifold or spacer.
BH |
1 Attachment(s)
BH,
The four hole gaskets are for use with the Q-jet four hole manifolds like this one. Use the open gasket with your manifold. Bob |
| All times are GMT -5. The time now is 02:18 PM. |
