-   -   Fuel Pump followup question (https://www.offshoreonly.com/forums/general-q/80258-fuel-pump-followup-question.html)
johnkot 05-31-2004 11:09 AM
I started to disconnect the fuel outlet and fuel dribbled out. Does that suggest that the pump is working or would engine vacuum as it's cranking over be enough to get the fuel through the new filter and through the new pump.
Background: My old pump was working but I had a strong fuel smell in the oil and the oil would thin.
Thank you all again for your feedback
JK
Strip Poker 388 06-01-2004 12:59 AM
Re: Fuel Pump followup question
The fuel pump would not cause the oil prob unless it was pumping over 9 psi.The fuel dilution in the oil would be from a rich carb.
Griff 06-02-2004 12:35 AM
From his other thread, I think he is talking about the gear lube in the sea pump.
