-   -   '99 Donzi 33ZX w/502 intermittant starting problem (https://www.offshoreonly.com/forums/general-q/80307-99-donzi-33zx-w-502-intermittant-starting-problem.html)
mjbtx 06-01-2004 12:29 AM
Just picked up a '99 Donzi 33ZX with 502's in it w/approx 100hrs;
A couple weeks ago, the starboard engine would start while out
after running awhile.....got home w/boat on trailer and engine fired
through perfectly. Yesterday, the port engine did the same thing
almost. It cranks through.....fired and idled for approx 4-5 seconds
and died....eventually it started fine. I have currently replaced
fuel/water separators and cleaned flame arrestor. Both engines
have approx 20 psi oil pressure @ idle and approx 40 psi running
up around 3-4000 rpm; Water temps are approx 170-180. Any ideas?
Griff 06-01-2004 12:40 AM
Re: '99 Donzi 33ZX w/502 intermittant starting problem
Sounds like a vapor lock problem. Never heard it talked about much on 502's, but several board members had similar problems with 500efi's.
Use the search function and search fro "vapor lock"
mjbtx 06-01-2004 08:59 AM
Any other suggestions?
robyw1 06-01-2004 09:26 AM
Is this an EFI or a Carb engine? Based on the year I assume EFI but I wanted to be sure.
Roby
mjbtx 06-02-2004 04:34 AM
It's a EFI motor.....
Von Bongo 06-02-2004 07:11 AM
All the 502's and 454 efi's can have this problem. It is a vapor lock issue that Merc has a tech bulletin out about. If I remember correctly you are supposed to let it idle a bit before shutting it down and always open the hatch to let the heat escape. Do a search here like Griff said and you will find it.
mjbtx 06-12-2004 09:43 PM
It's been running great now since I let the motors idle for approx 5 minutes
before shutting them down!!! Knock on wood....hope this was the fix.
