-   -   bravo 1 ? (https://www.offshoreonly.com/forums/general-q/80409-bravo-1-a.html)
rssteiny 06-02-2004 09:37 AM
bravo 1 ?
was changing my props last nite noticed that the one drive has a upper clunk noise that the other one does not have . i hear the noise when i spin the prop back and forth when it comes to a stop spinning it backwards. when spinning it over it sounds normal and i had no problems in the water over the weekend. a possible u joint or what.
thanks 32 thunder rick
WILDTHING TAZ 06-02-2004 11:39 AM
Re: bravo 1 ?
I Doubt It.when You Spin Your Prop By Hand You Are Only Turning The Lower Not The Upper. It Sounds Like You May Have A Bad Bearing Or A Chipped Lower Gear. Or A Worn Out Lower Gear Set.
rssteiny 06-03-2004 09:04 AM
Re: bravo 1 ?
thanks
any more info as to what i can check
