Doesn't the big donut seal #16 center the tailstock in the hole in the gimble assembly? Also keep in mind the hole in the gimble assembly in which the trans tailstock slides into is not aligned with the hole out side which the bellows is connected to. There is a step between these 2 holes which makes the tailstock appear lower when looking at it from the outside. You can see the step in the pic below the letter "A".
I do realize you also need the bolt stack correct. |
Originally Posted by phughes69
(Post 3723452)
I followed Brian's stack up but need to clairify if I have it right.
The way I assembled it was this from top down: Bolt/ head of bolt steel washer trans rubber mount fiber washer Thackery spring inside of the large steel washer fiber washer transom mount Nylock nut The part I am confused about is if there should be 1 or 2 fiber washers between the trans mount and the tailstock? I used this picture and Brians post as a reference. |
| All times are GMT -5. The time now is 01:31 PM. |
