k plane hydraulic line replacement
On a Sonic 31 the lines that crossed over the trim pump lines from the kplane
lines had a short .When they shorted the lines to the kplane burned a hole in one or both lines . We need to know how to replace the lines . do you pull through the kplane ? I can not reach the inside of the hull on the back side of the kplane . The short was caused from the stainless steel touching the positive terminal on trim pump. This is a new boat ,the dealer is 5 hrs away. |
Re: k plane hydraulic line replacement
You need to disconnect the line on the inside of the boat.
The lines are disconnected at the kplane pump however you cannot
reach the back side of the kplane on the inside. |
| All times are GMT -5. The time now is 11:48 AM. |
