502MAG very small oil leak
I have noticed a very small drip of oil below my port engine on the outside opposite the starter. I think I can see a little drip on a flat edge towards the back maybe part of the bell housing? Any ideas would be much appreciated. The engines were just put in 65 hours ago. Thanks.
Re: 502MAG very small oil leak
Have you re-torqued bolts or ck them?
Everything was re-torqued at 15 or 20 hours. Is there anything that can loosen over time? This little bit of oil drives me nuts as Im a fanatic about clean.
So this is on the port side of the port engine. Right?
Check the oil sending unit.
Port engine port side rear. I checked around that thought it was ok. I there anything back by bellhousing where a leak could occur?
oil press sending unit. OR
remote filter lines where the oil filter used to be. OR distributer |
Check all the valve cover bolts.
Check the bottom of the bellhousing if its wet could be a rear main. I hope not.
Where does your oil cooler run on the bottm or on the back check those lines too.
| All times are GMT -5. The time now is 08:49 PM. |
