-   -   Blower motor fuel pressure??? (https://www.offshoreonly.com/forums/general-q/80593-blower-motor-fuel-pressure.html)
Biggus 06-04-2004 09:36 AM
What is acceptable for fuel pressure on a blower motor?
I've been chasing a fuel pressure issue and put a mechanical guage on the motors. stbd motor reads 6 lbs WOT. Port reads 4 lbs and will drop to 3.5 after a while.
Is 3.5 lbs WOT too low or is this acceptable?
Thanks for the previous replies!
Kurt
GLH 06-04-2004 10:46 AM
Re: Blower motor fuel pressure???
Mine run 8 to 8.5lbs at idle and 6lbs at WOT
BlownBajaOnHavasu 06-04-2004 12:13 PM
3 lbs. is the minimum, if it is dropping on prolonged runs, you may have a volume problem.
lucky strike 06-04-2004 05:22 PM
6 lbs. here.
birdog 06-04-2004 05:28 PM
Same here.......3 & dropping would scare me
Fountaineer 06-04-2004 05:34 PM
A blower motor should never drop below 7 - 8 Lbs at WOT
