-   -   Speedo hose location. (https://www.offshoreonly.com/forums/general-q/81021-speedo-hose-location.html)
Jerry B 06-10-2004 02:17 PM
Can someone tell me where exactly the speedo hose comes thru the inside of a Bravo One? I have a pretty bad water leak and my speedo does not work.
It looks like the leak is above the tiller arm but not sure. Time was limited to diagnos and maybe I'm just paranoid after all I have read about the seal for the upper steering shaft. Also how much water will the tiller shaft seal leak. My bilge pump comes on every 2 or three minuets. I can see a pretty good stream of water but not it's point of origin.
BTW. This is a 1993 29 foot Fountain W twin 502's Both drives are way under water when sitting.
Thanks for help in advance.
Cord 06-10-2004 02:33 PM
Re: Speedo hose location.
The fitting is at the very top of the gimble.
Also check your bellows.
