Mercruiser serial number lookup
Anybody know of a good site for looking up Mercruiser engines serial number?
Re: Mercruiser serial number lookup
Thank you :)
Can anyone tell me the year of my 4.3MPI engine..the serial # is OM651192 Thanks so much
[email protected] |
Originally Posted by pmontrone
(Post 2971197)
[email protected] |
Based on http://www.brunswickmarineemea.com/f.../mcm_95-04.pdf I would guess it is a 2003 model year, but very close to the 2004 model year.
As I read it the serial no. for model year 2003 starts with 0M365640 for 4.3 MPI Alpha One models and 0M365680 for Bravo models. Model year 2004 starts with 0M656797 for 4.3 MPI Alpha One models and 0M655926 for Bravo models. |
Serial Number
Thanks for your help guys....in either case I'm pleasantly surprised because I pick up the boat for $1500.00 at an auction. It had bad gas and at the moment It dosen't start..any idea what I should do from here?
If I put gas in the throttle body it will start but once the gas is burned it conks out. Thanks again P.J. |
Mercruiser Engine
hello i have a Mercruiser the block# VM48B01722 I am trying to find out the year of this motor thanks for your help
your engine serial # is VM48B01722 I would double check that and see because no Merc serial # is going to pull up being VM48B.
(Post 2971543)
If I put gas in the throttle body it will start but once the gas is burned it conks out. Thanks again P.J. Wannabe |
| All times are GMT -5. The time now is 06:46 AM. |
