-   -   Compression on Merc. 1988 330hp 454?? (https://www.offshoreonly.com/forums/general-q/81351-compression-merc-1988-330hp-454-a.html)
FunHome 06-15-2004 11:35 AM
Help!!
My brother-in-law has to do a compression test on a boat he sold as a request of the buyer. What should it read??
I told him, I thought about 130lbs. but as long as they are all about the same it will be OK....right???
Thanks!!
Brad
FunHome 06-15-2004 12:08 PM
Re: Compression on Merc. 1988 330hp 454??
I changed it a little!! It's a 1988 not a 1998!!!!
They are leaving soon, anyone have a clue???
FunHome 06-15-2004 12:54 PM
I found it!!! In a shop manual I had!!
FYI, 150lbs.
Trippin 06-15-2004 01:25 PM
A solid motor won't deviate more than 5psi per cylinder, a leak down test in my opinion is a much better way to verify an engines cylinder sealing capabilites. FYI :Believe it or not an engine only needs about 60psi to run.
