-   -   502 EFI/MPI question (https://www.offshoreonly.com/forums/general-q/81525-502-efi-mpi-question.html)
thedonz 06-17-2004 05:43 PM
is the Mercury 502 EFI/MPI a good base engine to build up on a mid nineties Top Gun? what needs to be modified to make it durable if blower is added?
thanks
Chase910 06-18-2004 12:36 PM
Re: 502 EFI/MPI question
Yes. Some recommend swapping out the stock head gaskets with blower installs...my experience with the Whipple units is the stock parts work fine.
Breathe Later 06-18-2004 01:19 PM
Go with Fel Pro 17048 head gaskets. The exhaust valves should be inconel-Manleys or Ferrea. I sent my heads to Teague for the valve job, springs, etc. Make sure the crappy Mercruiser cast exhausts and elbows aren't leaking. Otherwise, stock exhaust will be fine.
Also, on a Top Gun, you're going to have to upgrade the Bravo's. Imco Extreme, Max Machine Worx, Teague XR are all good options.
