-   -   trim pump slowdown mean dying???? (https://www.offshoreonly.com/forums/general-q/81596-trim-pump-slowdown-mean-dying.html)
cooltoys61 06-18-2004 09:58 PM
one of my pumps is very slow and getting slower as if in a bind somewhere(drive was off not long ago)or voltage is low.(both batt used on both)I guess this means the motor is going bad?Can I buy the mtr seperately? or should I just get the whole unit.Thanks
cooltoys61 06-20-2004 11:35 AM
Re: trim pump slowdown mean dying????
ttt
38KV 06-20-2004 04:29 PM
Exactly the same happened to me today! :(
I'm going to tear down the motor tomorrow or Tuesday to figure out the problem.
I'll let you know.
cuda 06-20-2004 07:04 PM
Check the fluid level. Mine did that and I had a leak on the outside line.
cooltoys61 06-20-2004 08:37 PM
fluid level is barely below MIN with outdrive all the way up??Seems like if it were low fluid the motor would spin faster and not move the drive?
38KV 06-20-2004 08:52 PM
My motor was getting slower and slower and finally died.
The fluid level is perfect so I'm quite sure it is a motor failure.
ThirdBird 06-21-2004 11:17 AM
It's definitely the motor. Same thing happened to mine. Motor bad on one of my trim pumps and another bad on one of my K-plane pumps. Had them both rebuilt at an alternator/starter rebuild shop. Didn't cost much and now they all work well. Actually, the newely rebuilt ones are a little faster then the non-rebuilt ones. I should pull the other two.
Do the motors, I'm sure thats the problem and not the pumps.
cooltoys61 06-21-2004 11:48 AM
Thanks,I was wondering if they could be rebuilt. We have a good/cheap little alt shop down the street. It's never this easy with boats.
38KV 06-23-2004 10:28 AM
I took my motor apart yesterday and the brushes was totally gone.
Cleaned it and installed new brushes today, runs like new! :)
later 06-23-2004 11:28 AM
KV were did you purchase the brushes from. i have a motor that keeps quitting on me untill i go back and tap on it. i actually had a old motor laying around a swapped them out and works fine so i was thinking i'll replace the brushs for a spare.
later
