-   -   Bmax leaking water (https://www.offshoreonly.com/forums/general-q/81755-bmax-leaking-water.html)
zt260 06-21-2004 07:39 PM
Bmax leaking water
I just put a bmax on. It leaks water in the oil. About 1 quart of water on the last 4 hour run. I checked all the O rings top to bottom and nothing is bad. Anyone had this issue?
PatriYacht 06-22-2004 12:37 PM
Re: Bmax leaking water
I've heard of it. If you do a search on "B max", you'll find more info.
rbtnt 06-22-2004 08:21 PM
I had a leaky bravo last fall and found the bad seal by putting 10 psi in the vent hole and waited for the gear lube to leak out. Could that be done on the B-Max?
