Fuel pump problem solved
I wish to thank BAD_HABIT and GLH for your input. Evidentally there are several pump models that will fit an old (1986 454) but you may have to adjust the inlet and outlet. For anyone in the same situation the requirement is to remove the 6 screws that hold the 2 halves together and rotate it 180-degrees and tighten it back up.
It started right up. Thanks again. JK |
| All times are GMT -5. The time now is 05:00 PM. |
