Won't engage forward/reverse
Yesterday my son was driving 95 Formula 272 w 502/BravoI w/o any problems. He tied up next to another Formula as we have done forever. When he prepared to leave, he started the engine and put the shifter in forward, but the transmission didn't engage. Same thing with reverse. He checked the cable connections on the engine block and they seemed to be shifting. I am assuming a cable somehow busted inside the lower unit. Then he called this am to tell me that it didn't appear as if the unit was lowered in the water all the way and wondered if there was a fuse or something that might be "electronically" locking out the transmission. It seems to me that there is a fuse or something related to this. Any ideas. Thanks in advance.
kenny |
Re: Won't engage forward/reverse
Allways make sure your outdrive is down, if it is up to far the u-joints will not be able to engage the drive. This happened to me backing into a beach the other day.
Hope this helps mark |
If your lucky,, cable,,, if not,,, something in the upper gear set let loose. Was he shifting at idle? If it was shifted above 1,000 RPM on accident I would lean toward damage.
The best thing to do is pull off the back cap. You can see the gear set and shift assy right there. You will lose fluid,, if its shiny, theres your answer. |
| All times are GMT -5. The time now is 12:49 PM. |
