-   -   Sea Water Pumps and Pulleys (https://www.offshoreonly.com/forums/general-q/82587-sea-water-pumps-pulleys.html)
Shah Mat 07-03-2004 08:10 PM
I have a pump, bracket, and pulley which I think is from a 500efi. It has a serpintine belt pulley on it and no fuel pump hole. Can I just switch pulleys to use it with my V-belt system? Will it line up? Do I need a tensioner? Any suggestions?
Shah Mat 07-03-2004 08:15 PM
Re: Sea Water Pumps and Pulleys
1 Attachment(s)
Pic
Dusty Times 07-04-2004 12:24 AM
I'm not sure if it will work or what you are mounting it to but the 500efi's have blue billet alluminum pulleys. I believe most Merc belt driven pumps are the same and should work. Not sure about the mounting bracket.
