-   -   Another question about sea strainers (https://www.offshoreonly.com/forums/general-q/82625-another-question-about-sea-strainers.html)
Shah Mat 07-05-2004 08:06 AM
2 Attachment(s)
I bought a pair of Gil strainers off of E-bay last year and when they arrived the mating surface was loaded with RTV blue silicone. That leads me to believe they leaked. Thats probably why they were on E-bay huh? There is a rubber O-ring in there for sealing that may be flattened somewhat although it looks fine. I'm in the middle of my motor change and now is the time to install a strainer (I only need one). I don't want to install one of these and have problems down the road with the tight engine bay of a single 25'.
Has anyone had problems with leaks? If so, are they correctable?
Should I put the pair back on E-bay and buy 1 new one? If so, recommendations of longevity and easy cleaning?
I cleaned the blue silicone off of one.
GEOO 07-05-2004 08:19 AM
Re: Another question about sea strainers
How do they come apart for cleaning?
Do you have to unbolt all those bolts? Will you be able to get to it easily?
I have a new Gil Strainer, it has a single clamp and a thumb nut to clean it if needed.
http://www.gilmarine.com/products/seastrain/sstrain.jpg
Madmax 07-05-2004 10:05 AM
I have the newer style, and after 2 years of use, it leaked out the cap. I called Gil, and they sent me a new O-ring, and no problems since. I think it was 8 bucks for the 0-ring. Try that first.....
joe900sc 07-06-2004 08:57 AM
I'd recomend putting wing nuts on the cap. Otherwise cleaning those strainers would be a major project and most of those nuts will end-up in the bilge...
Shah Mat 07-06-2004 09:21 AM
I think they came with wing nuts and maybe the person I got them from had problems with them loosening. The planned mounting location will not be a problem for cleaning, just a problem to R&R if I have leaks or problems. This must be an older version of the one GEOO has pictured.
