-   -   Oil and Transmission temps? (https://www.offshoreonly.com/forums/general-q/82689-oil-transmission-temps.html)
MnFastBoat 07-06-2004 09:22 AM
Finally have everything plumbed and working for the Trans and Oil coolers. Aslo put in temp guages for both.
What is the recommended running temps?
Want to know how hot is TOO HOT?
Seemed to run about 200-210 for oil empty and 230-240 loaded.
Trans ran about 180-205 empty and 230-260 loaded.
At the stops you would see the temp climb and then once going again you would see the temps drop :) Guess the coolers are working :)
MnFastBoat 07-07-2004 06:10 AM
Re: Oil and Transmission temps?
What NO ONE pays attention to this while towing??
