Bravo to Arneson
Bravo's seem to be fine up to around 500 Hp then poof. Anyone try the conversion? But the real question I have is why not use an Arneson to begin with on a Cig, Fountain, etc. if using 500+ HP ?
http://www.arneson-industries.com/br...conversion.htm |
Re: Bravo to Arneson
16,000 was the quoted price for a bravo conversion. Thats alot of bravo's....
I put 6000$ worth of aftermarket shafts,xr gears,billet top cap,xr u-joints,shaft,hd upper to lower coupler,hd chrome moly tower ,bearings etc in my stock bravo after breaking it the 1st time,broke x/r upper gears after 50 hrs,another 1500$ worth of gears and brgs to get it going again,Sheared off hi-performance vert shaft at 90 hrs,another 1800$ in parts (new shaft/brgs/lower gears/o-rings etc) and so I wouldn't miss 2-3 wks of our short michigan boating season i spent 10,000 on another new outdrive w/all the above upgrades. That adds up to 19,300$ in bravo repairs in 3 years,16000$$ for something reliable doesn't sound too unreasonable to me ANYMORE!! I wasn't aware of this conversion kit with transmision mounted outside the boat,I was under impression i would have to move engine forward & relocate my back seat (not really a option on a 27 ft boat). There is next time!
Recent powerboat article pegs it a $50K/pair. Do you know where the difference is? |
The secret to keeping any drive alive is to keep it wet. If you start flying your boat get out your check book.
1. When you exit the water the engine over revs and if you do not throttle back before reentry the props hook back up hard and the drives absorb the torque as the r's reduce becasue of resistance. 2. Blowing drives is more common using 4-5 large blade props, that is prop sized that you do not achieve the mfg's specified RPM's when at WOT. This adds a lot more torque on the drive. 3. Bigger drives that will withstand that type of beating then place the load father up in he drive train system. The pressure plate which is actually designed to be the weakest link in the system and the cheapest to replace besides having to pull the engine. Arnesons are great drives. I have a set on a cat. I also have a Cig with 600's and Bravos which I have twisted. Just keep in kind, "You fly and they will die"! |
The ASD6 Kit/'Bravo Conversion" cost $16,000.00 complete with the components shown on our web site. Depending upon your current X dimension the motor might stay the same or be bit lower in the boat. We have not done a drive on a boat identical to yours, so I cannot tell you exactly how the engine will be set up. With your power the boat should be really fast. We have done many smaller boats but not necessarily with your power. See the 18' Donzi on our web site. If you have any questions, feel free to ask. Thank you, Rik Wimp Arneson Industries Dave |
For 2 of those conversion $32,000, no trannies and not installed... you get 8 Bravo's complete that install in 15 minutes or 4 XR's with a spare set of gears without the casing. And if PB says $50k for the conversion once installed with adding trannies and repositioning your engines, spend another 10k and you have 6's and then can run a locomotive in your bilge. |
1 Attachment(s)
I think Trannies are included: Here's a picture of the Kit.
If you've ever driven an Arneson, you'll never go back to an outdrive. Even in a single configuration, nothing will ever come close to the overall performance and handling, never mind the durability. http://www.arneson-industries.com/BtoAKit.jpg |
I was going to say that Geoo was the guy to talk to!
Tell us more about the before vs after handling, speed, planing, dial in, etc... |
| All times are GMT -5. The time now is 09:53 PM. |
