496 Mag
Re: 496 Mag
Originally Posted by blue thunder
As long as your oil temps are staying below 250F after WOT runs, 180F coolant temp is fine.
BT
BT
Re: 496 Mag
Bikinilover
The Merc. 496's come with a closed cooling system and a 160 degree thermostat. Most engines will run about 10 degrees warmer than the stat under light load conditions and may go to 20 degrees after a hard run. The temp of the water you are running in will also raise your operating temp depending on where you are boating.You might want to check your temp guage for calibration, 5 to 10 degrees off on some is common. Also make sure your coolant cap is holding pressure as a pressure leak here will raise the cooling system temperature some also. Doesn't sound like you have any serious problem as the Merc computer would go into the guardian mode if you were to hot.
Raylar
Raylar
TeamPSI
23
12-10-2007 05:23 PM
