Bravo exhaust bellows
I just received all new bellows for my Bravo. I am replacing them because my shift cable bellows is torn so while I have it apart why not change them all... My question is the "boot" I received for the exhaust is different from the one on the boat. The one on the boat is a bellows style and the new one is just a soft rubber boot. Is that a new design or do I have the wrong part?? They appear to be the same size and everything. Thanks for the help.
Re: Bravo exhaust bellows
There's the bellows type that's on your boat now, and I think there's also a "tube" type. I don't believe they are interchangeable. The bellows type expands and contracts as the out drive is trimmed. I think the tube type slides as the drive is trimmed. Be patient, no doubt there's someone here that can give you better info on the subject.
The slip type is interchangeable. It allows leakage to help reduce backpressure. It's used with some big block applications and the HD transom assemblies. When up on plane it may be a bit louder if you only have thru hub exhaust. Hope this helps.
Thanks guys. I have silent choice so not sure about the sound changing as I very seldom use the through hub. This is on a 502MAG and it doesn't really say anything about it in the service manual so I will try it and find out.
If you have silent choice and mostly run w/ thru-hull open go with the slip tube
good luck |
my bravo three came with the tube type...it will work fine.
it is a safer design as Falcon mentioned |
Thanks guys I am working on the install tonight and should be done tomorrow. I will let you know if I have any troubles.. Thanks again'
Well I installed a new shift bellows and u-joint bellows. The tube type that I received will not fit my boat. It is way to short even with the drive all the way down it does not even come close to the bell housing. Am I missing something???? or is it possible that the tube style exhaust bellows does not fit all Bravo 1 applications. The transom assembly is a 1991 and the outdrive is a 2001 model. Let me know what you think.
