-   -   Where is the water coming from?????? (https://www.offshoreonly.com/forums/general-q/83955-where-water-coming.html)
dowhat 07-27-2004 07:07 AM
Any ideas where water might be leaking into the bildge at??
I have checked the plug seal and it is good. I had my drive serviced recently and it seems to have started after that. I noticed when the mechanic put the drive back on (regular bravo 1) he just stuck it on and bolted it in... I'm sure he knows what he is doing but how does that seal? And should it be sealed.
THANKS!!
Doller Offshore 07-27-2004 07:11 AM
Re: Where is the water coming from??????
there are no gaskets if that what you're thinking,just a couple of o-rings on a bravo.
maybe a leak in the u-joint bellows? art
RedDog382 07-27-2004 09:32 AM
I had a leak around one of my drive trim indicators. Drove me nuts until I found it. Had to almost crawl under the engine to see a small stream down the inside of the transom. Pulled the flange, cleaned the surfaces, let it dry, then applied marine sealant and re-secured.
R-Don 07-27-2004 10:25 AM
Raw water Lift Pump Leaking?
Boss272 07-27-2004 06:47 PM
I have 1997 Boss272 with captains call, my y-pipe had come loose and was leaking badly. Had to pull motor to fix. Stopped the leak? engine has 280 hrs on it.
