-   -   Xr Drives (https://www.offshoreonly.com/forums/general-q/83973-xr-drives.html)
scottsumrall 07-27-2004 11:37 AM
Xr Drives
How Can Someone Tell The Diff. Of A Standard Bravo And An Xr. The Reason Is That The Drives Have Be Painted Red And They Do Have The Xr Stickers. The Drives Were Painted By Mercury.thanks
Doller Offshore 07-27-2004 02:20 PM
Re: Xr Drives
larger or heavy duty u-joint assy.
BadDog 07-27-2004 04:06 PM
Re: Xr Drives
Those two statements are correct for the XR and XZ. The upper gears is what you need to look at. The SN will tell you unless someone is trying to pull the wool over your eyes.
Mr Gadgets 07-27-2004 05:04 PM
Re: Xr Drives
Pull the top covers and look for gears with big ole teeth... there are pics of them all over the net..
RLW 07-27-2004 08:13 PM
Re: Xr Drives
www.go-fast.com/mercruiser_bravo_sterndrives.htm
Check out the site above for an explanation of Bravo Outdrive differences.
Thanks to Mbam for providing this information.
RJ1340 07-27-2004 10:25 PM
Re: Xr Drives
Bravo, XR, ZR, IXR....they're all going to break on you, so what's the diff?
P Offshore 07-28-2004 11:03 AM
Re: Xr Drives
The carrier in the Xr, (looking behind the prop shaft) is blue all others are not.
GLH 07-29-2004 06:39 AM
Re: Xr Drives
Beats sailing.
Sydwayz 07-29-2004 09:49 AM
Re: Xr Drives
Not true. I have XZ drives, and mine are blue!
Mr Gadgets 07-29-2004 11:06 AM
Re: Xr Drives
Sailing is like being towed in after your drive breaks.. but I would rather get the tow..
