Alpha Drive non-preload shaft design
Hi. I'm looking to buy a used Alpha drive (stronger non-preload vertical shaft style) with 1.5:1 ratio if anybody has one. Could not post in the correct section. Sorry to place here, probably will be deleted soon! Thanks in advance. I try to help when I can.
(734) 455-3734 Livonia, MI |
Re: Alpha Drive non-preload shaft design
Call me at 1-800-769-7698 I can get you a new one for $169.95
THanks Sean |
Check with
Sterndrive Systems Harrison Twp, MI 586-764-4611 |
These were both excellent resources. Thank you very much! I would not have found them otherwise.
| All times are GMT -5. The time now is 10:33 PM. |
