What is this?
I just took my prop off my bravo 1 and i noticed that there were this chunks of rubbers inside the lower where the shaft is, i got some pliers and took the rubber out also i saw in there and took off a little metal plate that looks like the bottom of an iron, im really puzzled about this finding, any help would be appreciated.
Carlos |
Re: What is this?
description is vague.
pictures or details please. |
Re: What is this?
1 Attachment(s)
Here is where i found the stuff
Re: What is this?
2 Attachment(s)
Here is what i pulled from inside there
Re: What is this?
Looks like part of an exhaust flapper
Re: What is this?
Definitely.
I was assuming you were NOT running exhaust thru the lower unit. Apparently you ARE running exhaust thru the lower unit and that is indeed an exhaust piece. |
Re: What is this?
1 Attachment(s)
This is the back of my boat, exaust thru hull not exaust.
Re: What is this?
That sure looks like a flapper disk. The port is oblong like that. If you never had through prop exhaust, maybe the drive was on a boat that did?
Re: What is this?
just because you are running thu hull does not leave out that you may still be running thru prop also
do you have the Y-Pipe? I currently run both the y-pipe and Thru hull so its possible |
Re: What is this?
I just replaced that Y-pipe flapper yesterday. That's exactly what it is.
If you do have a Y-pipe, you will want to replace the flappers. There is one on each side where the Y-pipe hoses connect the thru-hull pipe together. My flapper broke and it ended up letting water come back up through it, and filled my cylinders with water hydrolocking the motor. |
| All times are GMT -5. The time now is 04:27 PM. |
