-   -   Gil exhaust (https://www.offshoreonly.com/forums/general-q/84253-gil-exhaust.html)
Dangerous Dave 07-31-2004 01:54 PM
Gil exhaust
I just got done putting a new set of heads on my stbd motor and was about to put the exhaust back on and noticed some pitting and corrosion in the #8 hole in the exhaust manifold. Pressure tested it and sure enough water was entering the exhaust flow about 1 inch from where the manifold meets the head. So the question is, can this be welded to get me through the season? I think no but I'm not always right. I figure I might as well replace them now. Does anyone know if the IMCO powerflow has the same dimentions as the Gil? The tricky part is I have custom Stainless Marine dry tailpipes that exit the transom higher than stock so I need to keep the tailpipes. Or if anyone knows of a good set of Gil small block manifolds, any info would be appriciated.
Dave
Griff 08-01-2004 02:35 AM
Re: Gil exhaust
To use the tailpipes, you will have to use Gil manifolds. All brands have different bolt patterns. As far as welding???? Maybe, but its definately just a band aid.
Payton 08-01-2004 07:41 AM
Re: Gil exhaust
I had an exterior hole on a set that I bought. I had it welded and refinished. It looks and performs perfect. I would call Gil, I've heard they will repair them. Or maybe they can give you a tip on how to make the best repair.
Some Gils have a freeze plug type plug on the outside. It sounds like your hole is right behind that plug. For a complete repair the plug may have to be removed and welded from the inside as well.
Dangerous Dave 08-01-2004 04:59 PM
Re: Gil exhaust
Thanks guys, I will call Gil on monday. I didn't think of the freeze plug thing. If I can't get them fixed or find a set (they don't advertise them to be sold as new anymore) maybe I'll get custom dry CMI's made, that way I can really piss off the old folks.
Dangerous Dave 08-01-2004 05:00 PM
Re: Gil exhaust
I'm just kidding about intentionally pissing people off.
JON242 08-02-2004 10:25 AM
Re: Gil exhaust
Are the shorty headers available for small blocks?
