Bravo Shift Cable Tools
Can anyone tell me How thick the Plate is on Bravo Shift Cable Core Wire Locating Tool (Part #91-17263) This tool is used to hold the end of the Cable at the Bellhousing ?Also What is the center distance between the Hole( For the Barrell) and the stud on the Shift Cable Anchor Adustment Tool (part # 91-17262) This Tool is for setting the Barrell end of Cable at the shift Plate.
Thank You Rob |
Re: Bravo Shift Cable Tools
Rob, I have them. Your welcome to borrow them. Email me your address of you want.
You Have Mail.
Thanks |
Old thread, but looking for same info.
I have the core locator 1/4" thick plate. I need the distance between the brass barrel and stud hole for the tool ( 91-17262) used at the motor end shift bracket. I found where 1 person said it was 7 3/4" spacing, so I made that tool to that dim. But now I ran across a couple of replies that say its 6" spacing. Pretty sure once I check those measurements against the shift plate, it'll be obvious which one of those is wrong. Looking for verification of the actual spacing. Thanks |
It could be 7 3/4 but looks to me as closer to 7 7/8
https://cimg1.ibsrv.net/gimg/www.off...db4000f115.jpg |
I stopped using the tool because found it easier to set the height dimension on the shift plate first. Then with the motor running on muffs, pull the barrel off the plate and move the cable back n forth to find neutral. Don't need to look at the prop because you can feel it when its in gear. Once center neutral is found, slide it in place and your good to go
Thanks!
7.25" BETWEEN barrels, NOT centerline, with a .25" spacer at the helmet.
Originally Posted by 1 MAIDEN AMERICA
(Post 4620952)
If you buy a new cable and don't get NOS they also come pre-adjusted, so just check the 3 inch height and hook it
I just adjusted mine with the Merc Bravo Manual and verified with the 575 Installation Manual. I used the .25" tool at helmet and 7.25" spacing at barrels. Then remove those tools and install the centering tool on bellcrank to adjust shifter centerline. Then shift shifter to full forward and make sure notch in centering tool aligns with stud. If it's off adjust bellcrank pivot. Pivot on the bellcrank is supposed to be 3" center to center to start. That said, it leaves very little thread at the end of upper shift cable for the cable end to attach so I adjust each another .25". I don't know if my cables were assembled wrong or the SCX helmet throws the adjustment out of whack.
Originally Posted by AllDodge
(Post 4620457)
| All times are GMT -5. The time now is 02:40 PM. |
