propeller questions,,,
02 35 fountain snorting 575's about 690 hp ea.. tons of power
getting used to it now and starting to love the step bottom the way it runs... i am now running 31 hydro 5 blades and think my cruise speed is to low 1.50 gears. what slip should i expect with 2 in shorty sportmsters with 1 in spacer lets us 80 gal total fuel 2 people in boat..sluip should be???? 10% 15% 20%???? i am getting slip numbers of between 18-22% seems awfull high,,, at higher speeds i can understand the high slip as i run some tab over 85 to keep it from chine walking. according to fountains spec sheet on the boat the cruise was way higher etc. would the p5x s be better or merc 5 blades ?? will mercs fit with the shortys?? any thoughts?? |
Re: propeller questions,,,
throttle up?
sent email.. |
Get a hold of [email protected] He'll hook you up with what you need
Been busy with the storm that never hit us. Getting things back in order. I sent you a PM.
It shouldn't be a problem getting your boat to run better. Your boat is typical of the type of boat we deal with. Get back with me on the information I need and then I can make some reccomendations. Matt |
It shouldn't be a problem getting your boat to run better. Your boat is typical of the type of boat we deal with. Get back with me on the information I need and then I can make some reccomendations. Matt u all ok if u want call me when all is settled down 925 516 4654 jonas |
| All times are GMT -5. The time now is 07:40 PM. |
