Merc 502 MPI Tach bounce
One of my engines has a bounce in the tach at idle up to about 2500 RPM. I don't detect a miss and it doesn't seem to effect performance. Mechanic scanned it- no codes, compression OK, changed to plugs- still there. Any ideas?
Re: Merc 502 MPI Tach bounce
Check your electrical connections
Thought about that- easier said than done of course but hopefully that's all it is-
gaffrig
Thanks- I'll start there...
I had exact same symptons a couple yrs ago. Removed and cleaned the wire connections on the back of the tach and also flipped the 4-6-8 selector switch several times. Solved my tach bounce.
I am having the same problem. Please let me know what you find out.
US1, could you please explain what the 4-6-8 selector switch is? |
Short or bad ground somewhere
| All times are GMT -5. The time now is 11:56 AM. |
