-   -   please help with prop pitch on bL Hawk drive (https://www.offshoreonly.com/forums/general-q/85460-please-help-prop-pitch-bl-hawk-drive.html)
bubba 08-18-2004 03:53 PM
I now have the bravo1 gear ratio 1:50:1 and run a Houston propeller 23p and run 71 mph with 5200 rpm's some times hitting the rev!
If i buy a Bh Drive with 1:50:1 what kinda pitch would li need than to get the same rpm's
ore a BH with gear ratio 1:36:1 what kinda pitch do i need than please advice
Thanks allot Sake
Cord 08-18-2004 04:21 PM
Re: please help with prop pitch on bL Hawk drive
The blackhawk props were available in 3 pitches from merc. 27, 29, 31". This was the average of the two props. The front one is actually pitched more than advertised and the back one is less. The 29's are the most popular and thus are the lowest priced. I've seen them for around $800 a set. Don't forget you're buying two props, so that's a fair price. The higher you go in pitch, the more expensive they get. 31's start at around $1100 a set. The drives were available in 1:36 and 1.5 ratios. You proably could get one customized, I'm not sure. Do you see the problem? A 1.5 drive with 29" props will be too much for your current power. I'd guess that you'd be around 4500rpms.
throttleup 08-18-2004 05:18 PM
I would also recommend checking on availability on parts and props. They can be hard to come by!
Julie
blackhawk 08-18-2004 06:38 PM
Props are getting a little more scarce. Most of the internal parts shouldn't be a problem because they use Bravo I and Bravo III gears, bearings, prophafts, etc.
You may be able to pull it because the Blackhawk's prop pitch is a little deceiving because the whole prop isn't in the water.
But as stated in an earlier thread your hull has to have natural bow lift to use the BH.
bubba 08-18-2004 11:09 PM
Julie, thanks for the tip, the props would be the main problem, the are hard to get.
Cord and blackhawk, the 29 would be a Little to big on the 1.50 would the 1.36 with 29 be OK? please advice.
Cord 08-19-2004 08:39 AM
No, the 1.36 would actually make things worse.
Airpacker 08-19-2004 09:31 AM
You would maybe get away with a 150 drive and 27 props but I doubt you would be able to pull that combo to the rev limiter in your hull with that power. I went form a 28 bravo to 31 black hawks and stayed just around 5200 rpm.
blackhawk 08-19-2004 04:01 PM
What is your hull and power? You may be able to find a 1.65 BH. I tried one and my mid-range was incredible!
bubba 08-19-2004 04:29 PM
Blackhawk,
I have a Baja H2X with a 454 magnum MPI 385 Horses i would like to buy the right one and not buy two sets of props :)
blackhawk 08-19-2004 05:55 PM
bubba, I don't think your hull will work. Baja's have a lot of hook in the hull which require a lot of positive trim to lift the bow. Blackhawk's can't do that. I'd guess the only way you could get it to work would be modifying the bottom of your boat.
You'd probably get better performance with a shortie.
Cord 08-20-2004 08:14 AM
I had a repeated typo in my post. I should have been saying 27's. The 27's are the cheapest, and the 27's would be the closest pitch that you would need. Nevertheless, I'd still put a shortie on that boat instead of the hawk. I'd do a shortie and 24" Bravo 1. I'd also try a 26" in case the 24 is a little low. If the boat wants to chine walk, I'd then try a Hydromotive Q4. The only reason that prop isn't my first choice is because it doesn't plane off well.
