-   -   Trim Question????? (https://www.offshoreonly.com/forums/general-q/85501-trim-question.html)
tomtbone1993 08-19-2004 03:21 AM
Trim Question?????
Bravo outdrive, goes up or down then stops after a second. wait about 10 seconds, hit the button. Does the same thing works for one or two seconds then stops.
proboat-wes 08-19-2004 07:11 AM
Re: Trim Question?????
the motor has an overheat swich built into it,if the motor is dragging or the pump itself is putting to much load on the motor then the swich will open until it cools down,also low voltage corroded connections can also cause problems,low current with excessive amp draw will also cause overheatig.
