-   -   warning beeper (https://www.offshoreonly.com/forums/general-q/85534-warning-beeper.html)
JJONES 08-19-2004 02:08 PM
warning beeper
I Have 2 525sc In My Boat And After Running For 25min At A Moderate Pace,the Engine Warning Beeper Sounds For A While,i Then Shut Down The Motor And Wait For Few Seconds And Restart.both Sides Do This But When It Happens,its Not Always The Same Side,its One Side Maybe Twice And Then The Next Time It Might Be The Other Side,is This Common,has Anybody Had This Happen,what Is The Beeper Telling Me?thanks,justin
sgr 08-19-2004 02:12 PM
Re: warning beeper
I'm not sure about those engines specifically, but I think that in general the horn goes off for:
-low drive gear oil in the reservoir
-low oil pressure
-high water temperature
-Steve
JJONES 08-19-2004 03:00 PM
Re: warning beeper
All Guages Look Good,nothing Abnormal At All ,thats Whats Throwing Me Off
throttleup 08-19-2004 03:04 PM
Re: warning beeper
Check your impellers.
Julie
US1 Fountain 08-19-2004 05:25 PM
Re: warning beeper
Since the gauges look good, double check the fluid level in your drive bottles.
cig1988 08-19-2004 08:00 PM
Re: warning beeper
Isolate the warning system one at a time. As US1 said, check the drive resevoir 1st.
MnFastBoat 08-19-2004 09:13 PM
Re: warning beeper
I always thought there wer 4 things
but am drawing a blank of what hte fourth is from what is already listed
fuel pressure?
Fountainclimber 08-19-2004 09:23 PM
Re: warning beeper
Low voltage also sets them off.
At 10 volts, maybe not enough juice goes to the other previously mentioned senders but it will go off. My alternator went and I was running on the batteries untill 10V and then it quit shortly after that. Must be no fuel pressure or the injectors won't open. (500 EFI)
F
