Mercury Racing Remote Oil Filter
How do you know which line is out and which is the return on a remote Mercury oil filter unit????
Re: Mercury Racing Remote Oil Filter
Assuming you mean the oil filter t-stat unit used on the HP500's?
Ports on side with t-stat unit : Port closest to the mounting plate= OUT to cooler Remaining port closest to filter= IN from cooler Ports on Bottom of unit: Port Closest to mounting plate= IN, from block pad's offset center pad(Out from oil pump) Remaining port closest to filter=OUT, on to the center port at the block pad. |
US1
Thanks for the info. That is what I was looking for. I failed to mention the lines which fed the oil cooler. Do you know what temp the stat is to open? |
