-   -   Sonic Cavitation (https://www.offshoreonly.com/forums/general-q/85893-sonic-cavitation.html)
Penaltybox 08-25-2004 10:32 AM
Sonic Cavitation
I have a 28' Sonic. The boat has twin 502's. The props are 3-blade 25P, Mirage's. The boat has a BAD cavitation problem, when coming out of the hole, at more than half throttle, AND in rough water. Any suggestions???
throttleup 08-25-2004 10:50 AM
Re: Sonic Cavitation
Try a 4 blade prop this should eliminate the problem.
Julie
dyno 08-25-2004 11:07 AM
Julie
Got that right!! :rolleyes:
Cord 08-25-2004 11:10 AM
The bravo 1 will solve the problems that you are describing.
BobbyB 08-25-2004 01:52 PM
Ttt
BadDog 08-25-2004 04:57 PM
Are you running drive showers by chance? The Simrek can cause cavitation if the tube extends through the anti cav plate too much.
Dave M 08-25-2004 05:22 PM
I had the same problem with Mirage+'s on my boat. My prop would break loose and I would have to come off plane to get it to hook up again. I Switched to a Bravo 1 and the issue went away.
throttleup 08-25-2004 06:05 PM
Are the props Mirage's or Mirage Plus'?
What year is your boat?
Typically if your boat is difficult or impossible to get on plane with three blade props it's time to go to 4 blade props. Typically the overall performance of the boat will greatly improve with the 4 blade props
Matt
articfriends 08-25-2004 06:42 PM
Did it always do this since you've had it or is it something new? Are you running solid hubs? I had a 23 pitch 3 blade on my baot w/single stock power and it would slip a little out of hole but was fine the rest of the time,i put 50% mor power to it,tried a 27 pitch 3 blade,was super hard to get on plane and slipped almost identical to what your describing,solved problem w/4 blade.
