-   -   changing throttle/shifter controls (https://www.offshoreonly.com/forums/general-q/85949-changing-throttle-shifter-controls.html)
HiPerf2000 08-26-2004 01:25 AM
Friend is looking to change out his older style single (all in one) control to the zero effort separate shifter/throttle controls. this is a single motor setup. Will the cables need to replaced or just the ends? Also, does anyone have a used setup for sale??
cuda 08-26-2004 06:40 AM
Re: changing throttle/shifter controls
Just the ends. I'm doing the same thing.
HiPerf2000 08-26-2004 07:04 AM
Cuda, what shifter did you buy and where did you get it?
cuda 08-26-2004 07:17 AM
1 Attachment(s)
Gaffrig and I got it from poffshore
Ted G 08-26-2004 07:24 AM
Some cables have ends that are not removable, so he will need new cables too. And if you are doing the job, a new set of cables is a good idea anyway. Use the Teleflex TFXtremes-they make a world of difference in how the controls work.
Formula78 08-26-2004 08:44 PM
I did the same swap on my single engine Formula. I used the Mercury Zero Effort controls and TeleFlex Extreme cables. They worked great.
