Have Twins And Ya Loose One ?
Ya have a 29ft boat with twin small blocks and ya loose a motor due to failure of some sort. If the boat will come on plane with 1 motor is that the right way or do you slowly limp back ? And if it will come up on plane how far do you trim up non running outdrive ? INQUIRING MINDS WANNA KNOW ?
Re: Have Twins And Ya Loose One ?
I lost one in my 30 Victory awhile back and no matter how hard I tried, it wouldn't come on plane so I limped it. Problem was that the one prop cavitated just before it rotated and lost all forward momentum.
thats what I have been told ....idle home ...wonder if you were a LONG way ...could you swap a prop and get up ?
I like when you are flying under a bridge and have one run out of gas. Its a rush. I am glad I went swimming before, I had an excuse for the wet shorts.
Don't think you could ever plane with one and couldn't get the dead one trimed out enough to get out of the drag. I got 2 -450 HP 454s in a 29' fountain and nailed it once when my last one blew up and it wasn't even close to planeing. I think the drag of the dead one is the killer. Maybe with no prop?But I still don't think so.
I couldn't on one engine ever.
If someone has a twin that will get up with only one motor let us know- That hull will be on top of my list when I finally get to upgrade from my single sled...
Rick |
In most cases you will be well over propped to get on plane with one engine.
I've done it with my Formula , but only doing it a$$ backward. I got up on plane with two engines and killed one. The other could maintain it but come down off plane and thats it. If you could change to a prop 2 or 3 pitch's smaller it would probably work :) |
I would just guess that getting on plane would be a lot tougher than staying there but might be a few that can do it. I have only tried it on a boat with outboards and was a no go... heck with my luck the other motor would probably grenade from the load on the way back.
No go with my Kaama's for sure.
Sure. I keep a spare aluminum prop for a solo limp. Won't plane with a single 25", but will plane with a single 17" with no sweat. Not even hard on parts with that low of a pitch.
I'm pretty sure, a couple weeks ago, sydwayz said he got up on one with the Monsoon 37AVH :eek: :eek: And I don't remember him mentioning any prop swaps either. Maybe he'll chime in....
I lost one @90mph and keep it on plane at 50 until I got back to the marina. I knew once I got off plane it would be a long idle back in 95 degree weather. My problem was a loose coil wire.
I heard about people that did the same as mcollinstn. Carry a spare that is 8" - 20" less pitch. It doesn't matter with rotation as you can run either shifter backwards if need be. |
| All times are GMT -5. The time now is 10:41 AM. |
