Oil Temps / Pan or Cooler?
Ok, I'm running a HP500. I have two oil temp gages in my boat. The sending unit for one of the gages is in the center of the lower oil filter base at the back lower part of the engine. The other sending unit is in the block on the same lip that the oil pan bolts to.
The gage which has the sending unit in the block where the oil pan bolts to shows 260 degrees when I'm running it hard. The other gage which is reading from the center of the lower oil filter base is reading 225 degrees. Where should I be reading the oil temp and should the pan oil get that hot??? Thanks in advance, Mike |
Re: Oil Temps / Pan or Cooler?
the sending unitin the filter housing is reading the oil temp prior to the oil cooler.the other sending unit is reading it after the cooler. oil temps a lillte warn. are you running the filter housing with the oil thermstat if so by pass it. and check your temps agian
CMS,
Your saying that the sending unit in the center of the filter unit is reading the oil before the cooler and the one on the oil pan rail is reading after the cooler? That doesn't support what I'm seeing on my temps. Yes I'm running a T - stat unit on my boat and I have replaced the stat unit in it to make sure that that wasn't the problem and I seen no change. Thanks for the help. |
| All times are GMT -5. The time now is 09:24 AM. |
