x dimension on twins >
Old 08-30-2004 | 07:36 PM
Question x dimension on twins
Do you measure x dimension on a v hull with twins on the centerline of the drives or at the lowest point of the hull?
magnum is offline
Old 08-30-2004 | 08:44 PM
Default Re: x dimension on twins
After doing a little more research I guess what I'm really after is prop depth.I have a 87 Chris Craft 260 stinger project boat.I need one drive and found a pair of Alpha one ss drives and I'm wondering if they would be ok?
magnum is offline
Old 08-30-2004 | 10:27 PM
Tinkerer's Avatar
The ALPHA SS is 2 1/2 inches shorter than the stock ALPHA drive.
With a twin engine V bottom boat with stock X dimension if you run a straight edge off the bottom of the hull right infront of the drive it should go just under the cavitation plate on the drive above the prop with the drive level with the bottom of the boat.
Tinkerer is offline
Old 08-31-2004 | 04:57 PM
Thanks,I'm gonna throw a drive on tonight and check.
magnum is offline
Old 08-31-2004 | 07:07 PM
I checked the drive height and it's 2" from the bottom of the transom at the drive centerline to the cavitation plate.According to the previous post this seems alittle high,maybe the ss drives wouldn't be a good idea. What do you think?
magnum is offline
Old 08-31-2004 | 07:11 PM
I would think that would really work quite well with the right props. --- JP
jpclear is offline
Old 08-31-2004 | 10:21 PM
Tinkerer's Avatar
If your boat gets on plane easy with 3 blade props then it should get on plane with the ALPHA SS and 4 blade props -- OH and you should gain close to 5 MPH.
Tinkerer is offline
Old 09-09-2004 | 09:26 AM
yikes's Avatar
I have learned that the SS drives are only available in standard rotation units. I have an 86, 24 ft Daytona with twin standard rotation Alpha 1s. It gets twitchy at full throttle. Been looking for a counter rotation drive but no luck yet. Don't think I'd want to go 5 MPH faster with standard rotation. Let me know if stick with the SS and have a CR Alpha to sell.
yikes is offline
northernoffshore
Pantera
4
07-28-2008 12:42 PM
littledcsrodshop
Active Thunder
13
05-07-2008 09:33 PM
40FlatDeck
Skater
10
01-11-2007 10:28 PM
Elite Marine
Pantera
12
08-19-2003 09:14 AM
sambryce
5
03-04-2002 05:27 PM
