#6 prop loosens >
#6 prop loosens
#6 prop loosens
Old 09-01-2004 | 12:28 AM
27daytona's Avatar
Default #6 prop loosens
My starboard #6 drive prop loosens after a long run. The drive spins left and that seems to be the problem. The prop gets only slightly loose with enough play to wiggle on the prop shaft and it does set up a vibration at idle speeds and getting on plane. The port spins in or right and would be constantly tightening itself so doesn't create a problem. Thanks for any imput. Doug
27daytona is offline
Old 09-01-2004 | 11:40 AM
Default Re: #6 prop loosens
I have a single engine with #6 also turning left and have never had the problem you're describing.
check300 is offline
Old 09-01-2004 | 06:20 PM
Pwrbt33's Avatar
We had the same problem with our 38 Top Gun. I threw the old nuts away and bought new ones and we've not had a problem since.
Pwrbt33
Offshore Performance
1-877-GOFAST1
410-827-0200
Pwrbt33 is offline
Old 09-01-2004 | 06:24 PM
My Slingshot has Speed Masters. I change the nuts every season and torque to factory specs. Never a problem
Lmarth is offline
Old 09-01-2004 | 08:18 PM
Comanche3Six's Avatar
Sounds like the nylon in the nut has lost it's ability to grip the threads on the propshaft.
Like the other members have already stated, try a new nylon stopnut.
Comanche3Six is offline
Old 09-01-2004 | 10:27 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I had same problem last yr, but on Bravos. This spring I used new nuts and all has been good. Not sure how it always came loose with the nut always locked in the splined keeper. I don't think prop rotation has anything to do with it since the force is always pushing the prop forward against the thrust washers, 'cept when in reverse. Ya ain't doing any high speed reverse runs, are ya?
US1 Fountain is offline
Old 09-01-2004 | 11:09 PM
27daytona's Avatar
Thanks guys, I have replaced the lock nut but since they are much cheaper than props I'll replace with a new nut before the weekend run. I try not to do many high speed runs in reverse but with blower motors around the docks it does happen. thanks again guys. Doug
Old 09-02-2004 | 07:56 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Try shaving down two nuts to place two nuts on the shaft. Tighten them against each other, and they will not come off.
Sydwayz is offline
Old 09-04-2004 | 09:52 PM
also ck. the shaft for wear on the threads sounds like nylock is not grabing for some reason
tizbad4 is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
