-   -   HP500 (carb) Exhaust (https://www.offshoreonly.com/forums/general-q/86451-hp500-carb-exhaust.html)
ccarloss 09-04-2004 08:38 AM
What exhaust would you recommend/prefer on a hp500 carb? We may need to replace the GIL manifolds. Stainless Marine looks like a nice setup. Of course CMI is nice but a good bit more expensive.
Does anyone know if there is a performance difference between a good manifold and CMI's.
Thanks!
krypto 1 in CT 09-04-2004 09:21 AM
Re: HP500 (carb) Exhaust
did you check out the cyclone manifolds by hardin marine they are in they cp performance catalog.they are tubular sainless steel.there is a set that are direct replacements for the gill/merc manifolds so you dont need to do anything with risers just bolt them on with your existing risers.they look real good and are suposed to make a little more hp/tourqe though i would like to a see dyno sheet comparing them to the gills.show me 15 to 20 hp gain from 4500 to 5500 rpms and i would buy them today.
IndianaHeat 09-04-2004 10:17 AM
a less expensive option is lightning headershttp://www.cpperformance.com/images/310-4030.JPG
ccarloss 09-07-2004 08:04 AM
Thanks for the info. I did take a look at the Hardin GIL replacements. They seem about the same price as the CMI's.
p4-33 09-07-2004 09:10 AM
I bought my Fountain 10-Meter already rigged with HP500 carb motors running IMCO Powerflows. The advantage with these is you can set the motors at 33" on-center, with about 1/2" clearance between the manifolds.
The disadvantage is once you're at 33" on-center, you pretty much rule out using other exhaust systems. Most of the specs I've seen require minimum of 34" OC, and I think CMI needs 35" OC. Where are your motors currently set?
Also, does anyone have any HP gain/loss specs between the different brands (CMI, Lightning, IMCO, Gill, etc) ? I'd be interested to know whose headers perform the best, with some real numbers.
Thanks,
Brian
