-   -   MerCruiser Rev Limiter? (https://www.offshoreonly.com/forums/general-q/86548-mercruiser-rev-limiter.html)
gnimelf4 09-06-2004 10:06 PM
Is there a way to bypass the factory rev limiter on a 98 mercruiser 5.7, up to and including a new ignition box. If it requires a aftermarket box which would you use?
Badtoon 09-07-2004 08:09 AM
Re: MerCruiser Rev Limiter?
Well here I go again. I usually get spanked when I answer this but I changed over to MSD complete system for the same reason. There are other threads that cover the MANY choices for this. GOOD LUCK. I'm going to set back and wait for the MSD bombs to hit this thread.
Apacheagle24 11-23-2006 02:12 PM
Help My mercruiser 454 apache eagle 24 revlimiter cuts in at 5000 rpm and feels like this is killing my top speed how do I bypass or modify this thing for a higher rpm??
axapowell 11-23-2006 04:23 PM
I use the Crane Hi-6m. Works great, has timing curve and limiter built right in. Either Crane or MSD. Your choice!
Dave
Griff 11-24-2006 03:16 PM
There is no reason to change the rev limiter on a stock 5.7
It is making the most power/torque at the top of the recommended WOT range. After that, torque falls off a lot.
The best thing to do is prop the boat to run just short of hitting the limiter.
Griff 11-24-2006 03:18 PM
The best solution is to get a bigger prop or have yours reworked.
Strip Poker 388 11-24-2006 05:37 PM
I run MSD on all my stuff. Some people have bad luck with them,Ive never had a prob.The box on my old Scarab is still running from 1992
