-   -   Air Pump For 1991 Corsa Mufflers??? (https://www.offshoreonly.com/forums/general-q/86737-air-pump-1991-corsa-mufflers.html)
Ed 09-09-2004 09:56 PM
Circa 1991 Cigarette 31' Bullet with Corsa internal switchable mufflers. The air pump is no longer available from Corsa, they say. The system is simply, soft clear plastic push-on tubing(like aquarium tubing), with push-on barb fittings on the old air pump. Standard looking air cylinders...BUT...I need a new replacement pump. Don't have the old one. Anyone have a clue about a source for this??? Thanks, Ed
cig1988 09-10-2004 03:55 AM
Re: Air Pump For 1991 Corsa Mufflers???
Would merc pn 01534152 work? Just changed it on the '89 Bullet.
Ed 09-10-2004 09:21 PM
Cig...Do you have Mercruiser Silent Choice diverters or Corsa like mine? Ed
cig1988 09-11-2004 06:19 AM
It's the stock mercruiser silent choice. If it's operation is the same I could'nt see why it would'nt work. Check out mercruiserparts.com (BAM) and plug in the part#. Marc @ Bam would be able to tell you if it will work for sure.
