-   -   Flywheel expert required (https://www.offshoreonly.com/forums/general-q/87028-flywheel-expert-required.html)
fastlane40 09-15-2004 05:30 AM
Can anyone tell me if a billet FW1520 flywheel will suit a Gen V 502?
MESABALANCING 09-15-2004 08:12 AM
Re: Flywheel expert required
If its an aftermarket flywheel and it is a billet piece i would highly recomend to check the balance before installing it on anything.From my experience every aftermarket flywheel i have ever checked with a factory one has needed to be corrected sometimes more and sometimes less amount of correction but always been out. Sincerely Laz Mesa PS If you have your original we can always match them for you.
fastlane40 09-15-2004 03:14 PM
A Gen V or VI is still externally balanced but different to a mark IV.Is this correct?
fastlane40 09-15-2004 03:19 PM
[QUOTE=fastlane40]A Gen V or VI is still externally balanced but different to a mark IV.Is this correct?Is there a set amount of balancing weight to add to a nuetral balance flywheel to make it suitable for a Gen V?
